No power to CPU
vsananthu
No light is diplayed on the power switch even though the power is turned on.I tried replacing the power chord.Still there is no power.Can anyone help me solve this stupid problem.Please..............................................................................................................................................................................................................................................................................:confused:
Motherboard Intel DG31pr
2 gb ram
250 gb harddisk
Windows XP sp3
This problem started happening sudeenly after i heard a pop noise from the plug.If you can help please do...........................:mad:
2 gb ram
250 gb harddisk
Windows XP sp3
Sounds like your power supply blew. Might have even taken you whole computer with it. You wont know for sure until you try another power supply and see if it works.
A pop could have been one of many things: A GFCI tripping (check the outlet on the wall, if there is a reset button, push it), a fuse blowing (if you power supply has a fuse, replace it) or the PSU blowing (in which case you would need a new power supply and possibly a new computer)
