I'm still fairly new to overclocking, but what voltages are you running. Perhaps you should bump them up a little if you haven't already. And how about heat?
yah, always watch temps. The first thing I do after bumping up my CPU is to run 3 linpacks and watch temps. Then I run stability test. Which for me consists of running linpack until the cows come home
basically what you want to do is get your CPU as high as you can get it while still stable before touching any voltages. Once you hit a stability wall you start to tweak voltage while watching temps. I have never OC'ed an AMD chip so I am shy about giving detailed advice but overclock.net's AMD forum is a great place to ask questions and look for help.
How are you overclocking? In the bios or software? Are you increasing the multiplier or the bus speed to overclock?
What voltages have you tried?
Try unlinking your CPU from the Northbirdge and PCI-E things in the BIOS. That will allow you to get past some walls, if your bios has an option for unlinked or whatever it's called.
i am doing it the right way by doing it in the bios, i am using the multiplier and i have try going from 1.52 (default) to 1.6 or 1.7
not sure what that is
If your bios is the same as my old ASRock board, in the CPU section it will say ''Overclock mode'' and it will be set to Auto. Go down to that one and select "CPU, PCIE, ASYNC''.
Since you have a BE cpu you don't need to mess with the bus speed, just the multiplier.
no i have an advanced tab and under that i go to cpu, ill try out the amd tuner thing
Yes I know it's in the advanced tab, I skipped that part thinking that was assumed. When you are in the CPU section, there should be ''overclock mode'' and it will be set to Auto. Change it to CPU/PCIE/ASYNC mode. And also like I said make sure AM2 boost is disabled and Cool and quiet is off.
I know I was answering your question about what Linkin93 said.
so i should do this? i know i have this option
