Blue Screen of Death Again
wantedelite
Well I formatted my computer again into Windows Xp Professional SP3 with all the newest updates and everything than I install my Wireless Adapter and than I got the blue screen of death!
Errors: inql_not_less_or_equal, page-fault something not sure what it was
and there was one with the word crucial in it and some other ones too! What should I do? And sometime when I click sign in when msn pops up the blue screen comes up too ! What should I do im getting annoyed of this and no one could help me on my other thread!
Thanks in advance!
Thanks in advance!
Did you install all the drivers for your hardware? You can also blue screen from hardware failing.
You may have faulty memory. One chip on on your RAM stick might be bad so it would only BSOD when that particular chip gets used... example you open a program that uses memory.
I uninstalled it and downloaded avast seems fine for now atleast! thanks gotta make sure tmr
I'd say it'll be ok now
Don't know why you chose Avast over Avira, but that's people's personalities we all like different things
AVG and Norton tend to have network issues when corrupt or when a Virus/Malware is on the system.
Best to run another full updated scan with Avast to confirm clean
My wireless card will not work with XP. BSOD every time.
Same hardware on the same pc, running Windows 7 or Vista, the card works fine.
XP = dead to me.
