New build not working please help
kiwisteve
I have just built a new system here are my specs
MSI P55-CD53 Mobo
Intel i5 cpu
XFX Radeon HD4890
Kingston KVR1333D3N9K2/4G ram
AXP 630 watt power supply
Seagate sata hard drive
HP DVD/CD player
I push the power button and it flicks on then off with one very quiet beep as its turning off and continues to do this
Pretty much off the wall brand Power Supply to power a 4890. Plus did you put all the standoffs under the board in the right places?
are you getting beeps? or is the pc not turning on?
Did you connect the cases power to the motherboard? - okay i just saw that you said there was a beep, you will have to check the manual to see what that beep means, i will take a quick look.
I have read that one beep usuaaly mean ram problem i have removed and re inserted it and still does the same thing
it flicks on for 1 sec then back off with the beep waits about 3 secs and does the same again
These are the exact ram modules i have
please tellme they are the right ones for my mobo
KINGSTON Valueram/ 4GB 1333MHz DDR3 Non-ECC CL9 DIMM (Kit of 2) (KVR1333D3N9K2/4G)
well thats dual channel ram, and if the motherboard I sent you is the correct one.... then you have the wrong ram, Id create a new thread comparing your motherboard and ram and ask for an expert to see if they are compatible, i am confident the ram you bought is wrong, but get a second opinion please
Take Care
Incorrect.
The motherboard does indeed support Dual Channel DDR3 RAM.
Memory Standard
DDR3 2133 (OC)/2000 (OC)/1800 (OC)/1600 (OC)/1333/1066
Maximum Memory Supported 16GB
Channel Supported Dual Channel
