Some chipsets may perform better than others, but simply having conflicting brands makes no difference with regards to your video performance.
I would recommend staying all AMD/ATI...why not? That would just feel weird throwing Nvidia into the mix
Have you thought about getting an AM3 socket processor? Here is one just a bit more than the one you selected.
http://www.scan.co.uk/Products/AMD-...ion-Sok-AM3-32GHz-8MB-Total-Cache-125W-Retail
You can get an Asus evo for about 85
http://www.ebuyer.com/product/172846
That will save a bunch of money on the motherboard for some DDR3 RAMMaybe you can check ebay for decent priced RAM.
5 hours left
http://cgi.ebay.co.uk/2GB-OCZ-PLATI...M_JN?hash=item335629954f&_trksid=p3286.c0.m14
the nForce chipset is better that the 790FX chipset so ima stick with my choice but thanks for the recomendation!![]()
I'm not so sure about that.
Looks to me like the nForce 780a chipset only has 16 lanes for graphics, meaning one card would get 16x, two cards would get 8x/8x, and three cards would get 8x/4x/4x
The 790FX chipset has 32 lanes dedicated to graphics. While only two slots, you could run dual GPU cards at 16x/16x.
If I'm reading that right...
Check out this upgrade. I am bored so here is another idea
Triple core Black Edition
http://cgi.ebay.co.uk/AMD-PHENOM-II...CPUs?hash=item3a531779d2&_trksid=p3286.c0.m14
Gigabyte Motherboard
http://www.ebuyer.com/product/158608
4GB DDR3 Dominator RAM
http://cgi.ebay.co.uk/Corsair-4GB-2...M_JN?hash=item255695ce59&_trksid=p3286.c0.m14
You could easy sell your RAM you have now on here or on ebay.
