Can msconfig used to select and stop programs running at startup?
Yes, for diagnostics only
Once confirmed which "startup" is causing the issue, uninstall that program, or disable its auto-start entry in the program itself
MSConfig should not be left in Diagnostic Mode
Task shows many copies of "task manager" running. After stopping/eliminating task manager,
This really sounds like a Malware infection, have a read
HERE
Can running more than one firewall or virus program at the same time be an issue?
You cannot run more than 1
AntiVirus program, or Firewall at the same time; due to getting conflicts
If you are running two at the same time, select one to uninstall immediately
Update the other one, and then run a full scan
What does CC accomplish? Thank you
CCleaner will remove all temp files
The build up of Temp files can slow down your computer considerably (hence why I posted it)
Also temp files can get or be Malware infected (if an infection exists) so best to remove them anyway
Thanks for your questions, but did you want to follow what I advised?
It may be best that you do a full Antivirus and AntiMalware scan, since learning further about your system
