installing a new HDD
ReubenX
I have an IDE desktop and I have been running low on space recently so I bought a 250G IDE HDD as a 2nd hard drive
I believe I have installed it right,
-I set it onto slave with the pins,
-the master is on the end of the IDE cable and the new slave in the middle
-and the power cable for the slave comes directly from the port where the masters power is plugged in
My computer doesn't display the new HDD but Everest recognizes it
any idea why it's not working?
You need to go to "Disk Management"
Start > Run > diskmgmt.msc
Right click on your non formatted drive
Format it to NTFS (assuming your C Drive is also NTFS, of which it should be)
Done :)
thanx :D
I had to enable the disk and then format it.
19% so far, hope it works
double thanx for the quick reply
