jasonn20
I just bought this card http://www.newegg.com/Product/Product.aspx?Item=N82E16814102849
I ran a load test on this and noticed it was getting hot 80c @ 99% load for about 30min and the fan was only running 70%. Is there a better program I can use to set my fan speed according to temps? I know I can manually set it higher but would like for it to automatically adjust the fan speed. The ATI overdrive will kick the fan speed up to 75% but it has to be < 80c.
Thanks
Thanks
