DVI cable worth it?
viper110110
I just got a new 24 inch LCD monitor, 1920 x 1080, 2ms, 40000:1 dynamic contrast
the only problem is it only came with a VGA cable. It has the inputs for VGA, DVI, ad HDMI, but only a VGA cable. My video card has outputs for DVI (and 7 pin s video, but that's irrelevant) so would it be worth the money ($25 at Tigerdirect) to get a DVI cable, or would there be no difference?
Well are you a gamer? If you game then yes, I'd recommend it. But if your an average everyday user you probably wouldn't see a difference in it.. I switched to DVI just because I have it and it's a little better than VGA.
ya I'm a gamer, and I make games in XNA so I will be using it for that too.
I think I'll get one.
Except everything is closed today as it is thanksgiving :(
The conversion to VGA causes a small loss in quality. With a DVI cable the signal is not converted, it is kept digital, and goes directly from the GPU to the DVI input on the monitor.
You might notice a small difference. I switched from VGA with an old CRT monitor to an LCD with DVI at the same time, so it is hard to say.
