Stoic Sentinel
Can you guys suggest any good computer temperature monitoring software? Preferably freeware, but if I must, I'll buy it.
Alright, CPU all cores at 38C max, GPU at 59C max, and HDD at 33C max. Is that good? What would be the recommended max for all of them?
If your CPU is 38C, that's a good temp. Have you ran Prime95? Your GPU seems a little high, but different GPU's don't have the same temperature, so like said above, do some research on your hardware to see what the maximum temperatures for it.
If you want to do Overclocking, you need an after market cooler for your processor. The stock coolers that come in the box won't keep it cool enough.
