Need driver for FUJITSU MHW2160BH PL
You don't need drivers for hard drives. I assume you're having problems installing Windows? You need the SATA drivers for your motherboard/laptop.
yeah you r right... i am trying to install xp on vista laptop hp.... but it does not detect HHD .. where can i download sata drivers ...
Hmm... Confirm the disk is good, perhaps format and re-copy it. If it still won't work, I'd suggest looking for an alternative copy of the driver.
Also, on some computers you can set the drive to IDE emulation mode so no driver is required. Check around your bios. It's normally something like IDE/ACPI mode, IDE emulation, or IDE/SATA mode...
