upgrade advice needed please
nindisp
Hi,
I'm trying to decide which is a better option out of the two. A quad core or a i5 upgrade. If someone could point out how big an improvement the i5 setup would be vs. the quad core. I will be playing a few games e.g. fifa, football manager, civ4, and using for net, movies, spreadsheets.
Option1:
Intel Core 2 Quad Q8200 2.33GHz 1333FSB (Retail 775)
1x £79.95
Asus P5KPL SE Intel G31 Socket 775 Motherboard
1x £41.95
OCZ 4GB PC2-8500 DDR2 1066MHz Gold Dual Channel (2x2GB)
1x #42.95
option2:
Intel i5 750 CPU [2.66GHz, Retail, Socket 1156]
1x £155.19
ASROCK P55M Pro Intel Motherboard LGA1156
2x £83.89
OCZ DDR3 PC3-12800 / 1600MHz Gold Edition Low Voltage 4GB Dual Channel Kit
1x £74.69
G.SKILL DDR3 1600 PC12800 4GB (2GB x 2)
1x £68.94
I agree w Matthew. I'd go with the i5 just because I don't think quad-core is gamer friendly. I'd focus on getting 4gb of RAM and a nice graphics card if you want top game performance.
Hi,
Option1:
1x £79.95
1x £41.95
1x #42.95
option2:
1x £155.19
2x £83.89
1x £74.69
1x £68.94
The i5. Socket 775 is about dead. Plus the i5 would perform better. Get a better board then a Asrock. Gigabyte/Asus/EVGA/Foxconn
They are both Quad cores.
Imo just the pricing is a bit of an obvious answer :P
I have quad core @ 2.5-GHz and it is fine, but for future proof I would get i5 :)
Optional 2 if you can afford.
Or go for Athlon IIx4 620 + GA-MA770T-US3P + 4GB DDR3 RAM.
It should have a similar performance with that Q8200, but it would be more future proof than intel LGA 775
I can afford the i5 (even an i7), but if the quad core will do the job for £150 less then i want to consider it. I'm just trying to figure out if it is worth spending more or not?
Thing is I want to do a cheap upgrade if possible, and if the upgrade starts hitting £600 mark I may as well just get a new prebuilt pc with windows 7 as i will have to buy that too.
Could you recommend a better i5 motherboard?
I was thinking of getting a HD 5770 about £145 for the graphics card.
In gaming Athlon II X4 is not good, it performs worse than Q8200 most of the time
http://www.xbitlabs.com/articles/cpu/display/athlon-ii-x4-630_6.html#sect0
http://www.anandtech.com/cpuchipsets/showdoc.aspx?i=3638&p=8
The L3 cache seems to have big impact in gaming.
I would recommend to get Core i5 (or Phenom II X3 if he can't afford i5)
ATI 5770 not recommended unless you want DirectX11 and lower energy consumption
A 4870 1GB is cheaper and faster. And you can find faster 4890 at £150
http://www.ebuyer.com/product/172361
