just a noob
Well-Known Member
they get unstable at anything much above stock unfortunatelyFactory overclocked...my gts250 is factory overclocked but I still OC'd it 70 more mhz on the core and 250mhz on the memory.
Thats poop. Are those BFG's? I have had great luck with EVGA's stuff.
1 evga, and one bfg
Nice :good:
Have you tried to unlock your 550 into a quad? Should be able to do it with that board just set ACC to hybrid.
It's not defective. It's working exactly how AMD intended.... as a dual core CPU.Yes, I have spent couple of hours trying to make it stable but with no luck. Mine is defective.
Well since he is using the unregistered version, he can not change his setting, so we already know what they are.
Not saying he's cheating, just saying it's the stated rules on page 1.
Obviously a very fast machine and one hell of a 3D run.
Though out of curosity, how can you tell it's the unregistered version?
The results are online instead of on the 3dmark window
I can get online results with the advanced edition.
blah blah blah
shut your pie hole yoko
Don't you dare speak to him like that.
ok, shut your pie hole yoko
I'm going to sever your parents' bodies and make you feed on the entrails.
After you've excreted the said entrails, you'll then have to re digest them.
i hope this is satisfactory
I'd say it's good for the crown. Congratulations
Now, how much higher will it go? Do I hear twenty eight five?
