So, i want to build a gaming computer for $700 or less.
Here is what i was looking at,
Antec Three Hundred Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042
EVGA 896-P3-1257-AR GeForce GTX 260 Core 216 Superclocked Edition 896MB 448-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130433
SAMSUNG Black 22X DVD+R 8X DVD+RW 16X DVD+R DL 22X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache IDE 22X DVD±R DVD Burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151175
SAMSUNG Spinpoint F3 HD502HJ 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152181
case-$54.95
gpu-$169.99 after $30.00 Mail-In Rebate
optical drive-$29.99
hard drive-$54.99
Not sure about the os, 32 bit is fine if i can afford ddr3 ram.
Not sure on what cpu i would need, i would like intel if i can afford it.
Not sure what watt psu to get.
Dont know much about mother boards
Thank you for the help, if you want to suggest a different computer, go ahead.
I prefer newegg.com
case-$54.95
hard drive-$54.99
I prefer newegg.com
