Please help me with building my first gaming comp
smoothforprez
Hi guys I need help on picking out the components on my first rig. I've upgraded computers in the past but this is going to be my first from scratch. I plan to use this computer for mid end gaming, light video editing, and media. I would prefer to stay with intel and nvidia cpu/gpu. I also prefer microcenter because its nearby so i wouldnt have to pay shipping but i'm also ok with newegg and tigerdirect
My price point is roughly around $600
Things i'll be recycling from my old computer
22' moniter
keyboard/Mouse
CD/DVD drive
Operating system(windows 7 in the future)
Speakers
Wifi adapter
New Parts
Intel Core i5 750 Processor $150
http://www.microcenter.com/single_product_results.phtml?product_id=0317379
GIGABYTE GA-P55M-UD2 $110(see note below)
http://microcenter.com/single_product_results.phtml?product_id=0318192
BFG GTS 250 1gb $150
http://microcenter.com/single_product_results.phtml?product_id=0308087
Western Digital Caviar 640GB $69
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136218&Tpk=640gb blue
Ram unsure approx $80
Power suppy unsure $?
Case $?
Total $559+
I also have an unopened Intel e5300 cpu and a ASUS P5QPL-VM EPU mobo that i plan on returning, if you think either of those would substitute well into my build let me know
I read reviews on the motherboard(the one in the list) saying that a large gpu would block the second pci slot. if true would that mean that my wifi card wouldn't fit?
It looks like it would block a port, yes. But since there's 2 pci slots you could just plug it into the other one of them. Also with that motherboard, I'd go with some DDR3-2000 RAM, although I'm not sure if it would have to be overclocked for that, but it looks alright with it. 4 gigs costs about 120$ and I'd suggest getting more than that, but a budget is a budget. Looks like a pretty good build though.
EDIT: On newegg it says that mobo can handle DDR3-2200, but since you're on a budget that'd probably be over the top.
Thanks for the help would the difference in the ram be that big of a differecne? Because if so i could just hold off on it for a bit.
And also what wattage power supply do you think would handle the system?
I dunno, I think RAM is useless past 4GB (DDR3 2000) unless you're playing super memory intense games or multi-tasking like crazy ;)
wow ddr3 2200 ram is like $300, is it really that much better? what about if i get 4gb of 1333 since its compatible and then get more later on? Or suggest a different board altogether in the same price range that supports a higher variety of ram.
Honestly, I would doubt there would be that large of a performance increase, but generally when people build they try to reach the machine's full potential. You don't have to get the fastest speed, but faster is always better.
22' moniter
keyboard/Mouse
CD/DVD drive
Speakers
Wifi adapter
New Parts
Case $?
Total $559+
GPU - ATI 4870 1GB would be a lot better than GTS 250
PSU - min. of 500w
http://www.newegg.com/Product/Produ...2E16817341019,N82E16817194034,N82E16817371016
Case - Don't know about your taste/ budget. Here a some good one
Under $50 - Antec 200/ CM Gladiator 600
Under $100 - CM 690/ Antec 300/ CM HAF 922/ Antec 900/ Lian-Li aluminum case
Over $100 - Antec 1200/ CM HAF 932/ CM Cosmos 1000
HDD- Western Digital Caviar Black is faster than Western Digital Caviar Blue
RAM - Get something with DDR3 1600. there are plenty around $80 with free shipping
http://www.newegg.com/Product/Produ...1052315794 1052429371 4808&name=Free Shipping
Mobo - If you only install one video card, there is no problem with installing PCI slot
processor: Q9650 Core2Duo Quad 3.0 GHz FSB 1333MHz 3.0GHz 4*3Mb 64bit
Hard disk: Maxtor Diamond Max 22 1 Tb 7200rpm 32Mb
Ram: Patriot VIPER XMP DDR3 3x2048Mb 1600 MHz
Video card(VGA): Sparkle GT220-S3 1024Mb DDR3 256bit
Motherboard:ASUS P5E3 Premium WiFi-AP @n ix48 / ICH9 775s Quad ready, FSB 1600MHz, 3*PCI-E(CrossFire 2*16x, 1*4x), 2PCI, 4DDR3(1600MHz (2000MHz Over Clocking)), SB7.1, 2*Gbt LAN, 6SATA, 2*eSATA, Raid (0,1,5,10), 10USB, 1394, 2*WiFi AP(300Mbts 802.11n), ATX, up to 80.23% Energy Saving
If you want for gaming
Thanks i'll go with the caviar black. And as far as ram goes i was thinking 1600 in the first place i just wasn't sure if it was compatible with that board.
Thanks for your suggestions but i think this would throw me way over my price point for my $600 computer
