is this that special paste that everyone says is amazing http://www.newegg.com/Product/Product.aspx?Item=N82E16835150080
arctic sliver 5... your dumb not to get it....
..what? I was making a joke, not a suggestion.
arent they all designed for compression spreading
Well remember that 2-3c difference is quite alot on that graph, as if i remember right they were running a water loop which keeps the temperatures lower to begin with. Thermal paste will affect your delta t on air moreso than water.so the graph is saying that se 23 is the best but there really isn't a big difference in any of them. i mean does it really matter which one you use just as long as it isn't some off brand glue
A good graph to go by from [H]:
If your ordering from newegg, type "G751" in the search box. Its marketed by masscool, its just shin etsu G751. Its one of the best pastes but still about 1c higher than X23-7783D.so do you think that AS5 will be fine because i do plan to overclock but nothing that is too high because i don;t want my cpu to fry
