Catalyst 9.10 is out
What res u running at.
Shift is CPU intensive.
I had bad fps untill I got another quad.
See the NFS Shift thread by ellanky.
I have 9.10 installed :)
1280x1024, but that was on my old RAM & mobo, and i wasnt overclocked either.
does anyone know where I can get drivers for my 256MB ATI Radeon X1300PRO WITHOUT using the catalyst?? Ive searched high and low and havent found anything
What operating system are you using?
XP driver http://driverscollection.com/?file_cid=41106746670f1fea36990439055
Vista driver http://driverscollection.com/?file_cid=41106818874d5c5621fcd6fd575
Vista 64 driver http://driverscollection.com/?file_cid=41106819732734353da785c52e8
You should technically only be getting the drivers from the card maker but since they are no longer updating those old cards then you are left with doing this.
