i am getting an AMD Phenom II x4 and i was wondering what after market heatsink i should get
R rory129 New Member Oct 24, 2009 #1 i am getting an AMD Phenom II x4 and i was wondering what after market heatsink i should get
StrangleHold Moderator Staff member Oct 24, 2009 #2 http://www.newegg.com/Product/Product.aspx?Item=N82E16835118046 http://www.newegg.com/Product/Product.aspx?Item=N82E16835887011 http://www.newegg.com/Product/Product.aspx?Item=N82E16835103055 If you want to save a few bucks, cools as good as the above under load. http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=10008565
D Damorian New Member Oct 24, 2009 #3 The heatsink it comes with is pretty nice. Unless you plan on doing some very intense overclocking, you really don't need an aftermarket cooler.
Shane Super Moderator Staff member Oct 25, 2009 #5 Tuniq Tower 120 Extreme http://www.newegg.com/Product/Produ...C-C8Junction-_-CPU+Cooling-_-TUNIQ-_-35154008 Detailed info: http://www.tuniq.com.tw/Cooler_Info/Tower-120-Extreme.htm Great cooler!
Mr soft New Member Oct 25, 2009 #6 Wow some nice heavyweights there. That ZEROtherm scored really well in comparison tests. Kicked my Katana II's butt. I've been eyeing up the OCZ gladiator max for my next cooler. http://www.ocztechnology.com/products/cooling_products/ocz_gladiator_max_cpu_cooler
J Jamin43 banned Oct 25, 2009 #7 StrangleHold said: http://www.newegg.com/Product/Product.aspx?Item=N82E16835887011 Click to expand... If you're looking at the Zerocool - check out zipzoomfly's website. Can pick it up for 29.99 after 10.00 Rebate. http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=10006946&prodlist=celebros
G25r8cer Active Member Oct 26, 2009 #8 Get the V8 you wont be dissapointed. I have yet to see my 955BE go over 45c even after 4hrs on Prime95
FairDoos Active Member Oct 26, 2009 #9 Nevakonaza said: Tuniq Tower 120 Extreme http://www.newegg.com/Product/Produ...C-C8Junction-_-CPU+Cooling-_-TUNIQ-_-35154008 Detailed info: http://www.tuniq.com.tw/Cooler_Info/Tower-120-Extreme.htm Great cooler! Click to expand... Ive actually read some reviews where that cooler is quite shocking for cooling AMD chips apparently its worse that the Tuniq 120 (1st release) so might want to have a wee look at some more reviews
