Don't let your laziness keep you from a better cooler. The weight of any good quality heatsink needs a firm mounting system to mount it. Also you should just be able to unhook everything and leave it floating in place while the board is out.
does anyone know of a high performance LGA 775 cooler that uses the push pins
http://www.overclockers.co.uk/showproduct.php?prodid=HS-000-PL&groupid=701&catid=57&subcat=1395max budget is about 50 quid and yeah ypu gus are right ill take the mobo out![]()
Best cooler made...you'll just need a 120mm fan to go with it![]()
