assitance please
gilch
so yes, im a noob as to technical aspecs of pc's for the most part.
I play alot of mmo's online .. and the current game i am playing (AioN), is giving me huge rubberbanding and lag issues... and it seems im running at very low FPS. My current pc specs are listed below. I would like some imput on this - I dont really want to buy a new system at the moment. I would like to know if my current system is still decent.. and would it be beneficial on game perforance to upgrade video card(s) and memory, and cost efficient as compared to the cost of buying a new system?
thanks for your help
AMD ATHLON 64X2 DUAL CORE 3800 2.01 GHZ, 2GB RAM
NVIDIA GEFORCE 7900 GX (DUAL)
Just pulled this off Steam
Recommended:
OS: Microsoft® Windows® XP SP2/ Vista
Processor: Dual Core CPU 2.0GHz or equivalent
Memory: 2GB RAM
Graphics: NVIDIA® 6800 with 256MB RAM / ATI Radeon™ x800 with 256MB or higher 15GB hard disk space
DirectX®: DirectX ® 9.0c (6/2008 update)
Hard Drive: 15 GB hard disk space
Sound: Yes
Internet Connection: Broadband
You have:
2GB RAM
So i dont see how your having problems? Unless you have heat problems causing you to lag?
also check your setting high setting at the bare minimumm ram can cause it to slow down. im not familiar with that mmo does it have multiple servers, if so on a really busy server your gonna see a bit of lag.
+1 I was thinking of Internet connection to. It may not be a Hardware problem.
Whats the speed of your Internet? Do you have Broadband or Dial-up? (lol)
