Raidmax Aztec Mod
ScottALot
Okay, I have a Raidmax Aztec computer case. It's a pretty **** case and I'm probably gonna get an Antec 902 once my next build is complete. I don't want to just trash it, I want to do something MORE! Can any of you think of a mod to do? I don't want any really expensive mods, but don't think cheap as a primary.
Notes:
Top of case is very bare
The area where the drive bays are is VERY boring... just jet black :(
Inside is white :mad::mad::mad:
Right side is very bare and boring
BRAINSTORM, GO!
(http://tinyurl.com/yh28ann imagine the bezel white, not blue)
Notes:
BRAINSTORM, GO!
my wife has that case and i hate it..... 902 is a good investment
urgh what brought you in the first place to buy that case haha! :D
Anyways, Have you got sort of a theme you want to make or what? And what sort of other mods were you thinking?
I think some cold cathodes can spice up any case. they worked for my generic case. if the case is white get some blue cathodes, if it's black get some green ones. I also modded the side panel to fit a 140mm fan, and although i didn't really do it properly it looked ok and the cathodes where awesome at night time!
Id go with a sort of robot look with that case not sure how id do it but ill think up some ideas for you! :)
Have you thought of painting the inside of your case? Infact thats just gave me another idea hold on a sec :)
EDIT:
Ok so your see where your side fan is?
Your could make it more sexy by adding some honeycomb mesh there?
Also for the inside of your case if you dont want to paint it try and go for a carbon fibre effect using this film and maybe you could stick it somewhere else aswell?
Try going on MNPCTECH.com for more MOD ideas they also sell that carbon fibre film they do all sorts aswell give them a try :)
Yah, actually if you look at the 1st page, fluorescent paint was mentioned. I'll get some of that when I get all the materials I want together.
Where the hell do you get carbon fiber paint? I'd love to do that actually if it's possible.
EDIT: Oh, now I saw your edit... I'd rather not use that. I want it to be really easy to do and with this case it'll be a real challenge to get "stickers" to look good.
And with the fan, if I used honeycomb mesh it'd kinda ruin the effect of the blue pattern fan... you gotta see it in action.
I'll think about it... but where would I do it? All on the motherboard tray? And where do I put my mobo and all that stuff when I'm putting the stickers on btw?
All on the inside walls on the chassis and what do you mean where do you put your mobo? :confused:
