Sata hard drive help XP install
kxed
Ok this is my first build with sata. When I try to load XP it only sees 131070MB of my 500GB HD. The mobo shows 500GB I'm using a Gigabyte GA-MA770T-UD3P. Also witch sata port should I be using does it matter?
you should update your BIOS and get Service Pack 3 for XP, then see if your HDD space comes back.
try using something like Gparted to increase the partition size.
Ok I used nLite and slipstreamd SP3 into it and sata driverd now it shows the whole drive thanks.
also does it make a difference what sata port i use
According to the motherboard manual, it doesn't matter what port you use. On some motherboard there are some set for IDE and others set for raid.
