Okay, so here's what I've thought of.
http://bit.ly/65ZRuA Okay, imagine the front bezel, only white (it was like that stock)
Now on the front, there's this sort of cross patern going on. I want to extend that cross along the top and the right side of the case using white/metallic spray paint (w/e looks better)
On the top, I'm going to be drilling a circle for a 120mm CM R4 and put one of these grilles over it:
http://www.mnpctech.com/Computer_Fan_Grills_Laser_PC_Fan_Grills.html and spray paint the grille white.
The inside, I will paint black. Sorry, I just don't think the carbon fiber will really work, as there isn't too much to cover with it.
On the inside, I will spray paint the tool-less drive bay adapter things white or metallic as well as the container for the 80mm fan.
On the window, there was another 80mm fan, but that had to be removed for the heatsink. I want to put an 80mm fan grille over that just for looks, but spray paint the grille white.
