Thinking about a new gaming build $1500 Budget
ohh ok .. i gotcha... cause i looked up the Xeon processors.. they were under servers i believe. Also is that mother board xfire ready. I dont think it is. at least i didnt see the 2 pci express slots on it. I really wanna be able to go SLI or Xfire sooner or later without getting a whole new board. And also i want a board that will be able to use the next generation of processors. What are your suggestions on a board that is xfire and sli ready and able to run the next gen processors at the same time overclockable
The Foxconn Bloodrage has 4 pcie slots..and can do SLI or Crossfire(however, it cannot do triple sli or triple crossfire, but triple crossfire/sli is 99% useless anyhow)
And yes, Xeon processors are technically server processors. Thats why they are binned to run at lower voltages(and consequently because of running at lower voltages they tend to overclock better)
The bloodrage should support any upcoming 1366 processors.
alrighty ... so i wont see any preformance decreases just because its a server processor? also concerning the ram.. I hear the lower the timings the better... the timings on the ram u posted is 8-8-8-24 .... the ram i have in this machine is 5-5-5-15 .... should i look for lower timed ram or?
BTW thanks for all the help
Far greater difference in Mhz, that is 1600mhz DDR3, your running some form of ddr2. DDR3 has much higher timings than ddr2, plus 8-8-8-24 is about as good as it gets for 1600mhz at that price.
aight... and 1 last question ... having the Xeon processor which is a server processor for a gaming machine wont be a big deal..?
The phyiscal cpu is identical, just the voltages it runs at as well as a few options in the memory controller are enabled. Alot of people run xeons;)
nice.. now say... i buy that card.. later when i wanna go xfire do i need to buy fro mthe same manufacturer or can i get say a sapphire card at the same specs?
I could do alot wiht $1500!
