I am hooking up all my wires and cables. The audio cable that it attached to my case is does not reach it's spot on the MB. Is there an extension for that?
not sure which cable it is. BUT, check someplace like Radio Shack or a professional electronic store. I would be thinking your looking for a coupler. then you buy the length you need.
Another question I have, why would my dvd burner and hard drive not come with the cables I need? I have 1 data cable and that's it. Am I missing something.
I don't know. But im not using audio cables. sound comes out just fine. Others will reply though. For several years i have not need the audio cable.
somebody knows.
cheers.....
somebody knows.
cheers.....
