Letter Style
I did this to my desktop because the letters had a greenish tint and it made it better but I can not remember how I did it and I want to see if I can do it on my laptop.
There is a way to change the way the letters look on the screen,on my desktop I went to some kind of menu,then to color (from what I can tell) and in there you can change the way the letters look.There where several different things but the only ones I remember are text and photo.
Does anyone know what I'm talking?
My desktop in a Compaq w/ Vista and the laptop is an Asus K60 w/ Windows 7,if that helps any.
Thanks,
Im not using Vista but look in control panel / appearance and themes.
this should be available.
OK,figured out how I done it on my desktop.I actually went to the menu on the monitor,there was an option for color and in there I could change to a few different things.It was on "Text" and changed it to "Photo" and that done the trick. It's a Compaq computer and monitor.
Is there an option/menu on my Asus laptop that would allow my to do that?
