I play a game with the graphics settings at about medium, maybe a little past medium. In an area with moderate activity i get around 75-80fps. Christmas is coming and i do not have much I want, and i will be playing this game for a while a lot, so i was thinking of buying something to make the FPS even better.
I am running only a 300watt power supply, which is hear is pretty...bad. My graphics card supports a minimum of 300watts, and can overclock gpu to 750MHz, and Memory clock at 400MHz. So i was wondering if buying a higher power supply and bringing overclocking would increase my fps.
If so, would i bring up GPU or Memory?
Also, is there any requirements for a power supply, or can i just get what i can afford and put it on my computer?
Also, a side question: I noticed my LCD monitor only goes up to 75Hz refresh rate, while on my graphics card control center, i can set a maximum refresh rate of 200Hz, and when i try to set it past 75Hz, of course it says "Not Supported".
Would getting a monitor that has a maximum refresh rate higher than 75 increase FPS? And if so are there any requirements for that as well?
Thanks for your help.
