Router problem?
wooxie2
Hey guys, It's me again, and i need your help :)
I have D-Link Dir-300 router, and i have a big problem.
I use cabel internet. Cable comes to router, then with other cable to my Personal Computer, and wireless to laptop. So the problem is that laptop's internet is lagging. It is turning off after some time. For example i am watching youtube, and movies stop loading, google stops working, and firefox gets offline. I don't know what to do. I tried rebooting the router and changing cables, nothing. I dont know.
Please help,
-Wooxie.
Have you tried updating your wireless drivers? What about using an ethernet cable in the laptop to see if that works?
Yeah, more than likely it's a problem with the laptop. What programs are you running when this seems to happen, even if they are only running in the menu bar by the clock? I know some of the more recent versions of Steam have been causing a problem for some people(try reinstalling that if you use it). You could also try completely reinstalling Firefox. I had that happen to me once or twice with Firefox, especially after I had been digging through a lot of videos on YouTube.
Are you using your other computer or any other internet access at the same time as I have the same router and when two computers are in use the internet will slow down and then the router will shut down. It usually happens if you don't have a good broadband coverage.
Hope this helps *
Well, i did not updated any drivers of router, because i don't know how to do that, and firefox reinstalling does not help. It works fine with the internet cable. I am using wireless programs: Intel PROset wireless, and the signal quality is always good.
Sorry i did not replied earlier, i had no access to internet. :)
