installing ddr3 ram on new mobo?
Either the Blue or White as pairs. I would use the Blue unless you have a CPU cooler thats to close and you could move them to the White slots.
wow im glad i asked, i really was going to mix it up... how do you know for sure, I looked in the manual and I interperted them being installed white+blue , so blue will work?
Blue+blue or white+white, dual channel RAM works in pairs, so it only makes sense to put them in the color pairs ;)
You can use both white or both blue if you have 2 memory sticks. If you have 4 then populate all 4 slots.
sweet, the parts are delivered, i will be able to install this when i get home :)
I hope i dont have to troubleshoot at all, I do not have a floppy drive and when I install my cdrom, the IDE connector goes in primary slot right? or is it secondary, i always forget and pick the wrong one and my cdrom wont work
The motherboard you linked to on newegg only has 1 ide connector. Most newer motherboards will only have 1 IDE connector these days.
o okay, well i guess that sucks if you want a floppy... I also have a sata power supply, just install the sata power for the cdrom , can i use another sata cord to go from the cd rom to the motherboard and forget the whole IDE?
for the hard drive I can just use sata power and the sata cord also correct?
sorry for all the questions, you guys seem to know everything that im worrying about before i even get home
If you bought IDE roms then you will have to use IDE cables and 4pin molex power connectors.
I just looked the manual up and it said for two sticks use slots DDR3-1 and DDR3-3 slots, which would be the two white slots.
cool i just switched them to both white ones and it did boot up, but it wont boot if you install on both the blue ones. Is there going to be any difference now than when i mismatched them?
