Stoic Sentinel
...Spray paint my keyboard? I've been meaning to once I get money
, but I'm not sure how to get around to doing it and if it will screw it up or anything... your thoughts?
keyboard pic plox and i dont think its that safe, sticky keys much? but post the board lets see her
thats a good keyboard and mouse. leave it alone.
You will screw it up. Minimum, practice with a cheap keyboard.
My guess.......you won't like the results.
Use a 6" brush and non drip undercoat followed by 2 coats of non drip gloss, then bake in the oven at 200 degrees for 45 minutes.
Oh, just saw your post, I'll have to try that. Do you have a preference on a paint brand you can suggest?
Not really, I was boredwhatever brand it would be a mess.
I think it would work if you used auto spray cans with very fine layers to avoid any runs, and get a glitter spray.![]()
lol if you spray paint your keyboard your going to hate it, trust me.
Run down to Home Depot and pick up some plexy glass and make a window on the side of your case![]()
Hole cutting saw for your drill. They sell them at the home depot as well.
lol yeah i work there. basically, if we don't sell it, you don't need it lol
