Which monitor is better?
dirtbikeryzz
I'm building a computer online and i had a 22 inch monitor then realized for a doller more i can pick a 24 inch. Heres both monitors. The 22 inch--ViewSonic VA2223WM Widescreen WUXGA 1920x1080
24 inch ---24" LCD - Asus VH242H Wide Screen TFT Active Matrix LCD Display (Black)
pc specs
i7 960
GTX 285 SLI-Both 2 GB versions.
6gb DDR3 RAM
So i don't think performance on the bigger monitor would effect me.
One more thing both are the same res 1920x1080
my advice is to take the asus monitor....ASUS always was a good quality manufacturer ,you will not loose any performance with the 24' cause as i see your computer is good enough....
Yeah, not only is ASUS really good, I'm not too sure about how good ViewSonic is.
