linkin
You guys might have heard of baking a GPU. this may sound crazy, but it works. if you anything about BGA (ball grid array) and soldering, you can believe this. first, here are some links with success stories:
http://blogs.howstuffworks.com/2009/06/15/how-to-fix-your-graphics-card-maybe/
http://www.hardforum.com/showthread.php?t=1421792
http://www.ocforums.com/showthread.php?t=606658
And a how-to video:
[YT]R7jUqoKVY-k[/YT]
procedure:
1) Strip card of removal pieces
2) Cover a baking tray in foil, and make 4 balls of foil
3) Place the card GPU-down on the tray, supported by the 4 foil balls. (one on each corner)
4) Preheat oven to 400*F/200*C
5) Bake the GPU for NO LONGER THAN 10 MINUTES
6) Remove from oven and allow card to sit and cool naturally
7) Once reached normal temperature, rebuild the card and test
If you have a dead GPU sitting around with no warranty, give it a try!
I am seriously considering buying a dead card off ebay and testing this.
And a how-to video:
procedure:
