Post Your Cable Management
bomberboysk
cos im getting another 4890 1st then ill cool the both of them, still need to buy the motherboard blocks...
looking at a bigger case, mountain mod case or something similar
Hehe, get the ascension, will never need another case:p (Can actually put two motherboards in the duality)
Although if you only run a single optical drive in that case, the cost of all the fan grilles, fans, and 5.25" bay covers is another $100 or so(as their cases are case only, 5.25" bay covers, fans, and grilles arent included).
funkysnair
im looking at the pinnacle 24 with the quad fans on the top and tripple on the front, large window on the left side
http://www.mountainmods.com/pinnacle-24-cyo-p-498.html
aviation_man
I used to have good cable management but after my upgrades it just kinda fell apart.
Before Upgrades
After Upgrades
Are those two fans off to the right above the HDD floating in the air? :confused:
funkysnair
Same case im looking at getting actually. Just remember, the 5.25" front bay covers, fans, and fan grilles are not included. Same setup im looking at getting too hehe(quad/triple/window)
its a nie big case!! i would buy some pimping fan grills-maybe some custom ones!
Fatback
No, one is sitting on the hard drive and the other is mounted to what is supposed to be a 3.5" to 5.25" converter but I just turned it the other way. This one to be exact http://www.newegg.com/Product/Product.aspx?Item=N82E16817984005.
I only have them there to help blow the cool air from the front towards my CPU cooler. When I unplug them my CPU temps actually goes up about 2C so it does help with airflow.
poke349
Here's my Core i7 Lanbox - fully functional and OC'able.
Micro-ATX - I designed it that way because I knew I was gonna carry it on the plane to college.
It was pretty hard to do cable management because it was so cramped... :eek:
I had to sacrifice the second drive bay just to hold all the extra cables.
(click full-sized image)
More pictures:
http://www.numberworld.org/screenie_server/ushio_2.jpg
http://www.numberworld.org/screenie_server/ushio_3.jpg
http://www.numberworld.org/screenie_server/ushio_4.jpg
Anyhow, it still has room for either another full-sized video card or another hard drive. I can't do both because they'll block each other... :(
ScottALot
More pictures:
Wow! I'm surprised you got all that stuff in there. (Yes, that's what she said)
The Astroman
I see a couple of PSUs on the bottom of the case, sounds like a pretty good idea actually.
Love this thread, gives you good ideas :D
I just finished assembling my new build, and still have to work on cable management. I will post pictures when done!
