Plain and Simple---------Need Best Router
Rawlaw
Just as the title says my router is outdated and slow and i need to get a new one hoping to keep it under 150$ but is acceptable to go a little higher.
according to my dad we want a wireless N try to give him reason why we don't
THANKS
happy holidays
-Ryan
Wireless N will only make a difference if you plan on transferring files between machines, it won't give you faster internet speed.
good job u convinced him
he wants though a way to connect the printer to several computer so that i can print from anywhere in the house
(i think their is a component for that)
srry im asking u to do it but i'm working on getting a moniter sale ends today
Grateful
-ryan
Grateful
-ryan
The component you're thinking of is a printer server, basically a little box with a ethernet port and a USB port.
If you don't already have a wireless printer, you will need a print server. All you would need to figure out is if you want the server wireless or actually hooked up to the router with an ethernet cable. The printer would get hooked up to the print server via usb connection.
so basically ur asking if i want the little printer server box to be transmiting my data form the printer to the internet then from the internet to my computer wireless?
When you want to print something from whatever computer you are using at the time, the print job would go to the print server and then it would be sent to the printer.
Please tell me how many computers you have and if anything will connected wirelessly to the router.
