Need some imput on a build.
Video card - why not gts 250??
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130513&cm_re=gts_250-_-14-130-513-_-Product
Mobo + CPU - Get Core i5 + P55.
If you really want E8400, get P43/ P45. Since you are not using ATI card, X48 no use... And in long term, this is not a good option as there is limited upgrade ability.
RAM - DDR2 533 too slow. Get DDR2 800 is basic
http://www.newegg.com/Product/Product.aspx?Item=N82E16820211066
PSU- I would suggest getting a better quality PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16817189013
