Drenlin
Like the title says. I have a 10 year old Gateway tower that I plan to use for a non-O/C, Core i5 based system. pic:
With 5 external bays and 3/4 internal, it's definitely got the space, but I'm worried about cooling. It's only got one space for a mid-size fan in the back(pic), and the front fan/s will be underneath the faceplate here....there is an intake vent at the bottom of the face. Airflow through the faceplate shouldn't be a problem.
What I'm worried about is 1) what fans to put up there, 2) which direction to flow it all, and 3) if 2-3 fans will be enough to cool it. The fans on the front are lined up perfectly with the hard drives inside.
So...#1. I can either fit two 30mm fans hand have their full volume go past the hard drives like this, or I can get a much larger fan and have part of it be obstructed, and part of it blowing into the empty space in the case like this.
#2, I have no idea about. It seems like if I flow it front->rear like normal, then the hard drive/s could obstruct airflow more. Could they? Rear->front airflow seems a bit odd, but it also seems like it might be a bit more efficient.
I suppose #3 is what it comes down to. Will I be able to cool this thing enough to run a modern system?
edit: Guess I should include the model and whatnot. Tag on the back says "LP Mini Tower TB3 Performance 550". Looks pretty much like this fully assembled.
edit again: fixed links
