I will be getting the Megahalems for an i7 920. Wondering what are the best fans to get for it? Going for middle ground not to loud but decent performance. Also, Does it matter if it's 3 or 4 pin? What is the advantage of the 4 pin style over the 3 pin?
I used have one of those, great fan but overpriced for what it is. Best fans for the megahalems are either the Scythe Slipstream high speed, medium speed ultra kaze, or if you want something quieter a coolermaster r4.
What about this fan would it be good middle ground between noise and air flow?
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608004
Noctua NF-P12-1300 120mm Case Fan
Does it matter if the fans for my cpu cooler aren't 4 pin controled by the mobo? I don't want to have to moniter temps all the time.
At that point you should get a silenx fan, 90cfm and far better static pressure. Those noctua fans have generally poor static pressure.What about this fan would it be good middle ground between noise and air flow?
They are 120x25mm fans and rotate at a low rpm. Static pressure is the force a fan can exert, eg- more static pressure, more air actually gets through the heatsink. CFM ratings mean nothing without decent static pressure, and the only 120x25mm fans i have come across with even slightly decent static pressure are the slipstream and r4 fans. 120x38mm fans however easily have anywhere from double to triple the amount of static pressure of even a slipstream or r4. This is due to the longer trailing edge available on the blades, as well as a longer amount of time the air can be ducted/shrouded and directed through the heatsink.Care to elaborate?
