Wndows permissions
Linck
Well, I had Vista in a Hard Drive, And installed Windows 7 in another...
Now that i want to delete the Vista, I cant, I need permissions & Stuff.
But the problem is, How do i give my User in my other Hard Drive (Windows 7) permissions to delete the Windows Vista Files..?
Vista is in Disk C
7 is in Disk I
PS: I cant get on Vista anymore cause some files are missing...
- Open up My Computer.
- Right click on the drive you want to change.
- Select Properties. \
- Now select the Security tab. Here you can change permissions for the whole drive and and give your new user permission to change and modify files on the drive.
You will need administrative access in order to modify the permission settings.
Yeah, I tried that... But it gives permission to the User in Windows Vista instead of the Windows 7 one (Wich is on the other HDD)
what if you log onto vista and remove security and log onto windows 7 and remove admin security. Than when you are in windows 7 try to partition the hdd by delete the vista if you want to get rid of that os.
