Windows 7 suddenly giving me all sorts of dysfunctional problems.
andrewanimation
I just spent the last 4 days reformatting my previously-XP computer, installing Windows 7, and setting up all my programs just the way I like them, installing new drivers for the move to Win7, dealing with new problems of moving onto Win7, and so forth. The OS acted like an angel for the first 2-3 days, and now, suddenly, it's acting like a moron.
The '3 Stooges' of problems I'm experiencing very often while it's running is that it often likes to go slow/freeze/(Not Responding)/white window, or give me a totally black screen with just the mouse pointer, or it shows me nothing but the desktop background and the mouse pointer.
As for rebooting issues, I've seen it reboot my computer on its own before, as well as being unable to boot all the way to the OS.
Last night I did a fresh Win7 "Upgrade" Repair Install, though it didn't fix these issues.
I have no idea why it acted so nice the first 2 days, not to mention those were the most intensive days, when I pushed it to its limits installing programs and drivers. Now that I've finally settled in and began my more casual work, it's acting like it has no power whatsoever. This is not the best time to act this way, after all the time and effort I put into installing and setting up everything I use. How can I whip it into shape and move on with my life, withOUT going back to XP? (as I read online that you must reformat to go from Win7 to XP, which would undo 3 days of effort)
Edit: I forgot to say, I'm also always so unwilling to force a restart using the button on the tower.. I feel like the fresh reformat and Win7 Install I did 4 days ago should have alleviated me of such means. But then I'm often stuck sitting in front of a very slow and nonresponsive system, to the point that I feel it's necessary to force a restart. Explorer.exe also often isn't responding. I heard it's unsafe to End it though.
System Manufacturer: Tyan Computer Corporation
System Model: S2668 Tiger i7505
BIOS: PhoenixBIOS 4.0 Release 6.0
Processor: Intel(R) Xeon(TM) CPU 3.06GHz (4 CPUs), ~3.1GHz
RAM: 4GB (I usually only see 3GB of it being used)
Please list your system specs, in particular your amount of RAM.
Nah no offence mate,but I don't think that RAM is the problem.;)
I ran Windows Vista on 512 MB of RAM DDR1 and it worked like charm.:D
But of course if his RAM chips are damaged then its no wonder why Windows 7 works like crap to him.But of course.Like you said.Let him list his computer specifications.You never know.Maybe he has 4 GB of RAM,but 800 MHZ xD:D
Andrewanimation.First tell me is the Windows 7 you got the full version or is it the limited edition (not registered).Because if its the limited then after 3 days it will start giving you the black screen.You can always crack it lol,but that's against the rules and also illegal.
However if its registered and full version of Windows 7,I would like you to tell us the following things:
-computer specifications (like Mr. Zatharus mentioned already)
-how did you EXACTLY formatted the HDD and how did you EXACTLY installed Windows 7 and which version and also is it 32 or 64-bit?
-what drivers and programs did you install?
-what changes have you made in the OS options (Control panel for example)...?
-what was the LAST THING you installed and what were THE LAST OPTIONS you made to the OS?
-when did you notice this problem... - For example did you notice it after installing specific drivers or softwares?
Answer on these questions and I will be able to help you more easily.
By the way don't worry about this.OS is just a big peace of software and can ALWAYS be fixed ;)
Cheers mate!
EDIT AT 22:32 ---> I just saw your computer's specifications now.I can tell you for SURE that the reason is NOT your computer's specifications.Anyway answer me on other questions so I can know how to help you.
Cheers again :P !
Aw my computer can't use 64bit though. I assume it'd be too expensive/impossible to make a 32bit system become 64bit?
How do I find out how many MHz my RAM is?
Yes, it should be the 'full' version, as far as I know, but I'm not confident enough in my knowledge of Win7 to say for sure. It doesn't sound like something that would require an 'illegal' fix.
Are these comp specs enough?
I formatted the HDD by having the XP (not Win7) disc in there during boot-up and letting it reformat the disks. In the beginning of the process, I had to use a RocketRAID 172x driver for it to detect my RAID Mirror Array. In the new XP intall, I began the Win7 install with the Win7 disc, in the WinXP OS, not at boot-up, and I installed Win7 that way, through a few restarts, as normal. Once again, I had to make use of the RocketRAID drivers.
I installed all the drivers that Win7 naturally chose for everything I installed. The most mentionable programs included Adobe Photoshop CS3, antivirus and security software, Firefox, and Microsoft Office 2007.
Changes made to the OS in Control Panel included darkening the screen by lowering the Gamma and Colors, as NVIDIA didn't make a driver for my graphics card for Win7 (I'm looking into buying a new video card for this reason).
I installed so many things that I'm afraid I can't say what the last thing was (Winamp is a possibility, as it ended in "W," and I was going down my programs-to-install list in ABC order), and the same goes for any changes to the OS. But I'm not big on OS changes. I just needed to make it darker and let it install any drivers it needed for anything, such as printer/scanner, Wacom tablet, etc.
No, I didn't notice the problem occur after any drivers or software in particular.
Thanks!=)
The Windows operating systems SHOULD NOT be installed from Windows.You should boot the Windows OS you want to install from its disc and use it to delete all the existing partitions,format your new created partition and THEN install Windows OS,NO MATTER WHAT VERSION OF WINDOWS IT IS!
I do NOT recommend you to install Windows DIRECTLY from other Windows version.That is NOT a good way!Do as I said and everything should work properly...
I'll remember that for the future, but the only option I refuse to consider is to reformat AGAIN! Just spent the last 4 days getting the computer the way I like it, you understand.=)
Whoa there... What he did was fine and a normal way to begin an OS upgrade or fresh install on an existing system. There is nothing unusual or improper with what he did. The OS installer will normally reboot from the CD at some point. It sounds like what he did was install Windows 7 as an upgrade from a new install of XP. Is that correct andrewanimation?
Now, you mention that you are installing on a RAID array. Have you tried to install the OS onto a single drive? You may be having troubles with that RAID array or the drivers within Windows 7. Either that, or one of the drives is dying. Has the RAID card ever thrown up an alert on one of the drives?
I know lol,only I never make any upgrades because in some cases my computer works like crap after that.Not always,but sometimes it does.Weird but true.:D
Also I agree with you in one thing Zatharus.It MIGHT be that one of his drives is dying.But lets just hope thats not the case yet.Because if it is then he is ****ed up:D:D
As for the drivers,I don't think that should be the cause if he said that for the 2 days everything was working properly...
Anyway andrewanimation try to do what Zatharus told you.Do the same thing on some other drive and see if the problem is the same.If its not,then your old drive is probably dying...
If you are too lazy do do that,go in the "Safe Mode with Command Prompt" and type the following command:
chkdsk C: /f /r
(Where the "C:" drive is the partition where your operating system Windows 7 is installed to)...
Now click the ENTER button on your keyboard and if it asks you to restart your computer and you get choices "Y" and "N",choose "Y",press the ENTER button on your keyboard and then type the following command to restart your computer:
Shutdown.exe -s -t 0
Press the ENTER button on your keyboard...
After your computer has restarted,the disk checking process will start and LET IT FINISH!THE DISK CHECKING PROCESS CAN TAKE A VERY LONG TIME,BUT LET IT FINISH!
After the disk checking process is finished,your computer will restart automatically.After your computer has restarted,you restart it one more time manually by using the normal Windows restart option and after your computer has restarted again,tell us if now everything works properly...
I heard this was a problem with vista when it came out, but i dont think win 7 has the same problem, i'd hope.
