Win 7 64bit - 4.00GB RAM (3.50GB usable) WTF
Status
Not open for further replies.
linkin
Okay so my extra memory got here (thanks Aastii! :) ) and i got it installed without a hitch. i disabled maxmem before installing the RAM, so that isnt my problem. Problem is that i'm on 64 bit windows, it detects all 4gb but says only 3.5gb is usable.
My board supports 8gb max and has no integrated video taking a chunk of system memory...
I have heard something about "memory remapping" I will check my bios for any related feature.
EDIT: Searched my BIOS. nothing found relating to memory remapping :(
PS: If you don't know what memory mapping is, google it.
If you look at Task Manager in the Performance tab, are you perhaps using 500MB while idle?
Maybe Windows 7 shows how much the OS is actually using.?
When I had the Beta running on my i7 machine it showed all 6Gb of my RAM.
I don't have the RTM so I can't test.
isn't 32 bit only capable of 3 gigs flat? if it has 3.5 usable then it might not be the os then.
yes it does, but as op clearly states, he is on 64 bit windows :)
Don't know if it is the problem, but I have the same board as you and, obviously, used the exact same memory as you :). Because I jumped from 2 to 8 gb though, I didn't go to 4, however, when I upgraded, my system wouldn't boot with 4gb or 8gb in, only 2. It was because of voltages (that shouldn't be your problem, my memory uses more power than normal, or atleast to be stable) and (this is the bit that makes me wonder) because without the updated bios, it couldn't find the memory or even boot. Flashed my BIOS and what do you know, it works, so maybe you can give that a go.
I assume you have CPU-z installed, and if so, check your mobo, the latest bios version (or atleast the one that works) is revision 1301, so make sure you have no lower than that in
Well no my Windows 7 shows 4GB and nothing like (3.5gb usable) next to mine.
I wonder if the issue is perhaps your using a pirated version of windows 7 or a bad ripped copy of it (actually 32bit)?
00426-OEM-8992662-00006 = common key for a cracked version of 7 ultimate.
Just a thought but it is the only thing that comes to mind.
Check that the max memory tab isnt checked. Go into msconfig, Boot tab, Advanced options, and check that the tick box beside "Maximum Memory" isnt checked.
Status
