Hjt
Ok, while I am no
expert at this stuff, and you should definitely listen to the mods first before doing risky things (cause the moderators really know what they are doing), but I have a few suggestions. I noticed a few items in your HJT logs that
may pertain to registry problems
or a virus (could be one or the other, or both). Have you tried to run CCleaner in the registry mode? I use that tool quite often on mine and others computers an it has solved many problems.
If you haven't downloaded CCleaner yet, what are you waiting for? Its one of the best programs I have, and if your online as much as me.... you definitely need it. You can get info on it and also pick it up here at their home page:
http://www.ccleaner.com/
(While installing CCleaner, you will be prompted for several program options. I would recommend unchecking the Yahoo Toolbar option they offer with the download. Also if at that same stage an option for running CCleaner at startup is shown as checked, then
uncheck it.)
There are a few things this program can do. One is as a cleaner tool to rid your system of all the byproducts of many programs, such as items left in clipboard, cookies, cache, history, etc… and I run the cleaner everyday on my computer.
There is also a registry cleaner that scans for inactive, unused, unneeded, leftover registry items. This can help to reduce the chance of a virus finding a handhold on your system. I only run the registry tool once a month, and it automatically backs-up the registry before cleaning the registry.
(NOTE: I would HIGHLY recommend that this tool be run when nothing else is being performed on the computer, thus all other windows should be closed prior to using this tool and there are not processes running or about to run, like: an anti-virus scan, or when a Windows Update is running)
To Run the Cleaner Part of CCleaner:
Close all open programs (especially browser programs such as Internet Explorer, FireFox, Google Chrome, etc...)
Open CCleaner on the desktop
It should open straight into the Cleaner tab
Click ANALYZE (it will take longer to analyze depending on how often you run this tool)
Once it finishes analyzing click the RUN CLEANER button at the bottom
Your computer is clean!
To use the REGISTRY tool of CCleaner
Click the REGISTRY tab
Click SCAN FOR ISSUES and allow it to run
Once the scan is finished, look through the list and see if there are any items you wish to be untouched, uncheck those. (I usually uncheck any registry items related to my anti-virus program.)
Once you are ready to clean the registry click FIX SELECTED ISSUES
It will run, and fix the registry.
DONE!
*CCleaner has many other tools such as a UNINSTALL tool and a START-UP tool, both are very useful and I have used both many times. These are both located under the TOOL tab, use them as needed.
And in response to some people talking about the HJT reporting
(file missing) entries... the file
is there, HJT just isn't seeing it. You need to be very careful that you don't delete those entries just because you see that bit on the end of the HJT log line. The (file missing) does NOT mean that you can assume its a malicious entry.
If you see that on a line and are suspecting the entry as malicious or unneded, then I'd recommend for you to: post a question here about the entry in question, Google it to get info on it and its status, use CCleaner registry cleaner to check for missing/damaged registry entries you may have.
That may help some, but it seems like you have some problems other than that. Its starting up slow you say... how slow is slow to you? I only ask because everyone has a different conception of how long a start-up should take.
If you could record in minutes & sec how long it takes to go from pressing the on button to the operating system fully running ready to use; then post your result it may be helpful. For instance, it taking 2 minutes to get going is "ok". If it takes over 10 minutes to start-up, yeahs you guessed it; "...Houston, we have a problem!..."
To make your machine start-up faster and run better, there are a lot of start-up & service processes that do not need to be enabled. Items such as jsched, realsched, the Google updater, java quick starter, adobe updater/loader, AIM, AOL anything for that matter, do not need to be OK'd at startup or in running services
As always, be careful what you disable. But if you see entries
such as "Real Player" updater on the msconfig start-up tab, yes its ok to uncheck it.
Cleaning the start-up, services tabs on msconfig of unneeded apps can usually add loads of speed to any computer. Also go into all your programs and check for updates. Real player, Google Earth, Java, and a few other programs are really bad about not updating like they should. Also check to be sure you have all the necessary Microsoft updates installed.
If you have the Google Toolbar, or the Yahoo Toolbar; chuck 'em both. And I believe you can remove them both in the CCleaner tools section. If not then go to add/remove programs and remove 'em.
OK, I'll stop here so I don't turn into a VISTA optimization post.
Well I would recommend that you get SUPER AntiSpyware, its a great addition in any computer! ha ha ha
Do ya get it? "...addition in any computer..." I laughed when I wrote it! ha ha ha
OK...my fiancee gave me the "your a dork" look when she read that, so dumb, dorky jokes aside; Super A/S is a great tool that I was shown recently. It does a great job scanning and looks in places and for things that your A/V and MWB may miss.
IF you want it, this is their homepage. You can DL it there.
http://www.superantispyware.com/
Give that a shot and see what comes back.
And
I would not take it to a store like that (Staples is what I think you said). Ive personally seen some real problems from those types of places, especially since its a "free day" promotion. Everyone will be taking their computer in, and the people there will most likely give each computer a quick once-over. They're probably just gonna do something like scan with anti-virus, maybe delete the temp files, and then check for windows updates. Its your choice though, never know till ya try, eh?!
And what did you mean by "...but the Dell dude hopped up on my computer..."? Do you mean they helped you via remote assistance?
