Computer info-
ASROCK ATOM ION 330
Intel Atom Processor Oc'd 2.1 ghz
2 gigs ram
Windows 7 64 bit
I had Windows 7 running perfect, but decided i wanted to give Moblin a shot. I shrank the windows partition just shy of 5 gigs, renamed it, rebooted and installed. The install formatted the 5 gig partition and finished sucessfully. After the install, moblin booted as my primary os but froze at the logo screen... so i booted back in to windows 7 through the moblin start upscreen to look for possible solutions and after some digging decided that I dont have time to deal with tweeking.
Here comes the PROBLEM- I used disk manager in windows to delete the moblin partition, Then expanded the windows parition by the five gigs moblin was using. I shut off my computer and went to bed. Next morning....turn her on and it just says grub> blinking _
ASROCK ATOM ION 330
2 gigs ram
Windows 7 64 bit
