crossfire
JareeB
will i be able to crossfire with the hd 4670 and 3200, and would it be worth it? still waiting for my hd4670:D
The 3200 will give you no discernible boost in performance and probably cause you more issues. The mixed-mode crossfire setup has not been terribly stable. You are better off just waiting for the second 4670.
well i only have one express pci slot, so yeah you think the 4670 will play gta 4 and mw2?
if you have the 4670 1Gb, then yes, more than likely you will be able to play GTA4 and MW2. the 4670 1gb is better than a standard 3870 512mb
