Phenom 965 125w overclock
jasonn20
I want to see what the max is for this inparticular chip. I have it running a 4ghz @ 1.45vore now but what about the NB and HTT? What should they be set too? I am wanting to run 3dmark with this new cpu.
MB: Gigabyte GA-ma790x-ud4p
CPU: Phenom 965 (125w)
Ram: G.skill DDR2 (2x2) 1066
GPU: Sapphire 1gb 4870
Heatsink: Zigmatek DarkKnight
OK ... 4ghz @ 1.45vcore (will push higher)
NB + HTT @ 2200 (not sure)
ram maxed @ 1066mhz 2.1v
Gpu 4870 @ 790 - 1000 (slight overclock)
3dmark score --- 17,349
attempt #1 I am a far cry off from 20k dang!
attempt #2
3dmark 17,488
Cpu - 4.12ghz @ 1.5vcore
NB HTT same (not sure on best setting)
ram same (should be maxed)
Gpu - 790 -1030
attempt #3
cpu - 4.20Ghz @ 1.55vcore (try to bump again)
same
same
gpu- 855-1040 (may have some more)
3dmark 18425 (getting to the edge i think)
attempt #4
Cpu - - - 4.20ghz @ 1.55vcore (best I can do with air cooling)
HTT + NB - 2050mhz (stable with overclock)
Ram - 1100mhz
GPU - 875 - 1030
3dmark 18636
I had a Phenom 550 x2 @ 3.8 that scored 15000 with the same setup in 3dmark why does a quad only give another 3500 points??
Because a 550 at 3.8 is not a bottleneck in games. So the SM2 and SM3 scores won't go up much, it's the CPU score thats affected the most.
OP- You will not see 20k with a single 4870 and Phenom II cpu on air. You kinda already found that out though. Best I could get was 18k with my 550 unlocked to a quad at 3.9ghz (1.575 Vcore!) and about the same clocks on a sapphire 4870 1gb. My gtx260 scored 19.5k though haha, Nvidia FTW!
