GTA IV Help
Problem
Ummmm, ok, what with?
Sorry for the long reply and not including the problem in the first post.
The problem is with the in-game video editor. When I'm playing what I'll do is hit F2 to save the what I didn't even want, then let recorder run untill I'm done, but when I go into the video editor no matter what the clips are always like less than 30 seconds.
I'm guessing you are used to using FRAPS, where you press the hotkey to start recording and press it again to finish. GTA IV is different.
With the clip capture, you need to do what you want to record in the game, then hit F2 afterwards. It will save a clip of the past minute or so of gameplay.
I realized this, but every time I record the files are only 20 seconds, is their anyway to make it save like 10 minutes?
i got a GTA 4 question too
if i use xfire to record gta4 video or anything will that slow it down alot? if im getting maybe 40 50 frames?
When I use Fraps and Xfire I get down to about 30-35 when I'm normally 60, but I just prefer the in game editor because the quality is absolutely amazing.
