Twist86
I am getting sick of opening my case when I want to do backups/storage so I am trying to find another method and turning a old PC into a storage system sounds good on paper
My thought process is I will still have to have a "main" with a OS installed (as I don't see it working without) but all I really need plugged in is a keyboard and then the part of figuring out how to connect the two systems.
I know I could "connect" the two via network but that wont work as my box is 40 feet from the original PC and I don't want to go under the house again ^-^ so I was thinking is it possible to link 2 systems via USB and if so can I treat it like a multi-drive system?
Example I click on the system icon then select C-D-E-F-G drives then drag and drop the files (so I can sort my drives out)
I dunno if this is possible and I can do network if its the only way but one way puts the PC in my room and the other makes me get up which after a 10 hour day I don't like to do
