Froztblade
I have a new build, which will use an estimated 320W (based on this)
I have a Coolermaster 460W XtremePower is it likely to be sufficient?
And if not how far would I have to go for sufficient power to maintain decent efficiency?
Edit:
Realised it might be useful (Idiot that I am)
System specs:
AMD Phenom x4 965
Sapphire HD4850
4gb (2x2gb) Corsair dual channel kit
3x120mm case fans
Advice would be muchly appreciated.
Thanks.
Edit:
System specs:
AMD Phenom x4 965
Sapphire HD4850
3x120mm case fans
Thanks.
