my first computer build...help?
terminator
hi all so i want to build my own computer. i just want to make sure im on the right track. and i need some help finding a computer case under at least 30$/maby40$. and i cant figure out what kind of ram sticks to get a friend recommended 4GB i haven't bought anything yet so here are some parts i was thinking about. i did some research on the motherboard and processor and i rely like them!
i have cd drives fans and hard drive.
here is the motherboard
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4316659&sku=P450-9124
here's the processor
details.asp?EdpNo=4089662&sku=CP1-DUO-Q8200
the graphics card
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4089662&sku=CP1-DUO-Q8200
monitor
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3591418&sku=H94-1940
power supply
details.asp?EdpNo=3986693&sku=A107-1117
windows 7
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5213932&sku=M17-7302
and if theirs anything else i need
THANKS!
those links on tiger are obsolete,
but as far as i know your gonna need at least 4gb ddr2 ram by the look of the board, i would suggest:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231144 x2
then your case and pcu if you looking to save money should probably be bought as a bundle so i found this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147129
it has a 500w psu so it should be enough for you needs.
also your gonna need a hard drive, so i found:
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136320
oh and optical drives so heres:
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118032
ok sorry about that lemme try again.
i did some more looking and found that the mother board does not have seta plugs witch i need. and what exactly does overclocked mean?
lemme try these links again
motherboard
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5270971&sku=P450-0010
processor
video card
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5077920&sku=E145-9636
or this
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3749879&CatId=3585
case
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1901962&sku=TC3J-4050 P
also getting a monitor with DVI hook up, the ram is going to have to wait i have enuff for it to run, and windows 7 64 bit.
again im sorry im rely not good with this kinda stuff
dont worry, it looks fine but you still need a hdd and i would get a 550w psu, i would also go with the second gpu. and are you 100% decided that you wanna go with intel you could get a better cpu for less with amd.
http://www.newegg.com/Product/Produ...iption=&Ntk=&CFG=&SpeTabStoreType=&srchInDesc=
its not a whole lot less but it is a faster cpu and you get more bang for you buck with amd.
the thing is i need a socket 775 processor amd doesn't seem to have that.
is the core 2 quad a good processor? im not gong to be doing anything real serious.
Lol, yeah, Socket 775 is an Intel socket. AMD sockets are (ex: AM2, AM2+, AM3). Can you elaborate on "nothing real serious?" But a C2Q should be fine.
sorry i wasent clear. i know its an intell i was just aking if the c2q is a deasent processor
well, no serious gaming media things like that
