I believe we're going to need more information than just your chipset. If you give us your motherboard make and model, it would make it much easier.
foo dang, as in a song?
yes from ABK
I believe your machine has a Intel® Celeron® Processor 440
which means it is socket 775 which means it is the same socket as the core 2/ core quads.
but i cant find any information to know wheather or not it will support these cpu's
Use CPU-Z or a program like it to check for sure but this should be your motherboard CPU support.
Likely it will not be able to support a Core 2 Quad Processor because it is an E-machines system.
