anbo369
hi,
straight to the point my Aero Peek in Windows 7 isn't working and i was wondering if you guys have any ideas on how to help me because i have tried everything to get it working.
lets go to the start:
when i first installed Windows 7 it worked fine no problems (i loved it!!
) but then a couple of days ago it just dissappeared and stopped working.
I have tried going into toolbar properties to see if it has been disabled, but when i checked it was ticked to be enabled and it is also grey (so that you can't change it) and i'm not sure why that is. But it is enabled and i'm not sure why its not working.
I have tried using all of the "hacks" i could find to get it working, however the only problem is that when i go to do the "hack" the values are already set to what they should be to be enabled.
So i am completely and uterley confused, the only hint i can give you is when i do a troubleshoot to find issues with and of the Aero effects it tells me that my "Desktop Windows Manager" is disabled. But i have done a google search and found where DWM is located and it is enabled so i am not sure what is happening.
thanks for your time and sorry about the really long post!
P.S I know that my Computer is capable of running Aero Peek because it used to work. See sig for specs
cheers!
cheers!
